co-pilot question??
0078265317
I got the 5 dollar co-pilot. And premium is 20 dollars. Just noticed the 20 dollar is gone and is replaced by a 10 dollar version. Is it the same just price dropped?? And also what is improved since the thew 5 dollar version?? Or is 5 good enough??
If any one has this and knows thanks.
If you are talking about CoPilot USA Standard & Premium then it looks like the $10 version is their top version. Seems like a very good deal. It does go on sale fairly often, but this doesn't show it as being on "sale".
The $5 version does not have voice navigation nor 3D view. Scroll to the bottom of the app description & it mentions what features are in each app.
"....IN-APP UPGRADE TO VOICE-GUIDED NAVIGATION
For a premium navigation experience, upgrade to the full CoPilot Live voice-guided, turn-by-turn navigation via in-app purchase, and enjoy: 3D map views, speed limit warnings, and realistic ClearTurn™ display with lane indicator arrows at complex intersections....|
The 5 dollar does have voice. It does speak. But I don't have data on att prepay 10 cents a minute. The stupid execs said no more data for 10 cents a minute people. So I'll stick with my 5 dollar standard for now. I'm from Illinois so yes standard USA is the app I use.
CoPilot doesn't need to be connected to data for navigation, only for downloading maps which you should do over WiFi or things like traffic reports, fuel prices, POI further info, sending location info via text or email & perhaps dome other extras.
Do any of you know if yo can use Copilot for route planning and then create and export a .gpx file?? I have a Garmin Oregon handheld that I use when navigating on trips on the motorcycle. It navigates fine, but is limited if you want to plan a route due to the small screen. I'd like to plan routes on the bigger screen of my Nexus 7, then export them to the GPS. I don't want to use the Nexus to navigate while on the dirt bike, I want to keep it secured in a padded case. Thanks. I've been looking for an answer to this for a while now.
