Apps Code not working. Please find error
this is my activity code:
package com.pal.dialog;
import android.app.Activity;
import android.app.AlertDialog;
import android.app.Dialog;
import android.content.DialogInterface;
import android.os.Bundle;
import android.view.View;
import android.widget.Button;
import android.widget.Toast;
public class DialogActivity extends Activity {
CharSequence[] items = {"Google","Microsoft","Yahoo"};
boolean[] itemschecked = new boolean[items.length];
/** Called when the activity is first created. */
@Override
public void onCreate(Bundle savedInstanceState) {
setContentView(R.layout.main);
Button btn = (Button) findViewById(R.id.btn_dialog);
btn.setOnClickListener(new View.OnClickListener() {
@SuppressWarnings("deprecation")
public void onClick(View v) {
// TODO Auto-generated method stub
showDialog(0);
protected Dialog onCreateDialog(int d){
switch(d) {
case 1:
return new AlertDialog.Builder(this)
.setIcon(R.drawable.ic_launcher)
.setTitle("This is a dialog")
.setPositiveButton("OK", new DialogInterface.OnClickListener() {
public void onClick(DialogInterface dialog, int which) {
Toast.makeText(getBaseContext(), "Ok Clicked", Toast.LENGTH_SHORT).show();
.setNegativeButton("Cance", new DialogInterface.OnClickListener() {
Toast.makeText(getBaseContext(), "Cancel Clicked", Toast.LENGTH_SHORT).show();
.setMultiChoiceItems(items, itemschecked, new DialogInterface.OnMultiChoiceClickListener() {
public void onClick(DialogInterface dialog, int which, boolean isChecked) {
Toast.makeText(getBaseContext(), items[which] + (isChecked ? "checked!" : "unchecked!"), Toast.LENGTH_SHORT).show();
}).create();
return null;
Please put your code inside either
Code:
 or [high] tags.
Also, you haven't given near enough information for us to go on. "doesn't work" is too vague. What doesn't work about it? Does it throw an Exception? If it does, please provide a copy of the log cat output. If no exception is thrown, but it just doesn't do what is intended, well then, you need to tell us what exactly it is you are trying to do and what your app is doing instead.
HI
I have created a button. On click of that button it should show me a dialog box. Clicking on button doesn't do anything. In the logs also i am not getting any error or anything.
Hi
Shouldn't you use the same id in onCreateDialog as in showDialog? You use "0" in showDialog but expect "1" in onCreateDialog.
