alostpacket
Over Macho Grande?
Before writing any files to the user's storage (usually sdcard) you should always check to make sure it's available to write to!
This will save a lot of headaches with strange errors in your code cause by the user forgetting they mounted the sdcard via USB.
This is just part of one of my methods in my FileUtil class. I will try and post these kinds of tips as regularly as I can
You can then call it in an if statement like this:
For more info, see the Environtment class documentation:
http://developer.android.com/reference/android/os/Environment.html
Code:
//From class FileUtil.java
* Checks to see if the storage is available to be written to
* You should still check individual files .canWrite() methods
* @return true if the external storage is writable
public static boolean isStorageWritable()
boolean storageWriteable = false;
String state = Environment.getExternalStorageState();
if (Environment.MEDIA_MOUNTED.equals(state))
storageWriteable = true;
return storageWriteable;
Code:
if ( FileUtil.isStorageWritable() )
//write some files to disk
else
//inform user there's a problem
