Apps [Code] Quick tip: How to write a .nomedia file
alostpacket
Over Macho Grande?
Hi all,
Just a quick code snippet on writing a .nomedia file to a directory.
All you need is a path to the folder you want to write to.
Notes:
- the TAG varible is just the name of the class (in this case "FileUtil")
- the D varible is just a boolen to indicate you want to debug or not
Code:
 * @param   directoryPath   The full path to the directory to place the .nomedia file
 * @return   Returns true if the file was successfully written or appears to already exist
public boolean writeNoMediaFile( String directoryPath )
    String storageState = Environment.getExternalStorageState();
    if ( Environment.MEDIA_MOUNTED.equals( storageState ) )
        try
            File noMedia = new File ( directoryPath, ".nomedia" );
            if ( noMedia.exists() )
                if (D) Log.i ( TAG, ".no media appears to exist already, returning without writing a new file" );
                return true;
            FileOutputStream noMediaOutStream = new FileOutputStream ( noMedia );
            noMediaOutStream.write ( 0 );
            noMediaOutStream.close ( );
        catch ( Exception e )
            if (D) Log.e( TAG, "error writing file" );
            if (D) e.printStackTrace();
            return false;
    else
        if (D) Log.e( TAG, "storage appears unwritable" );
        return false;
    return true;
