consultant
New to Android. Loved having essentially what I call 'collapsible widgets' on my old iPhone 4 on the lockscreen (jailbreak.) Essentially when text messages, emails, calendar event reminders, or even SportCenter updates came in, they would show up in a widget on the lockscreen (ala Intelliscreen X app) and you could do an action (like delete/clear the notification), or you could collapse the widget so that there was just a header like 'SMS Messages (3)' with 3 being the number of unread and you could uncollapse it to see the messages. The widgets would just always stack up together. If they didn't all fit, you could scroll down to see them. If all the info in a particular widget that was open didn't fit in the widget's window, you could scroll down to see the rest of the info. All this was done on the lockscreen.
Granted, I didn't have any sensitive information to worry about people seeing. But you could choose, just like Android what shows up and what doesn't.
In running Jelly Bean 4.1 with Sense+ (4.5) on the HTC One X+, I found I had to install WidgetLock to get control of the widgets on the lockscreen. I'm using Pure Calander Widget Agenda and the widget stays the same size no matter if there are no events listed or 20 events. Sort of a waste of lockscreen space.
Is collapsible and/or scrolling widgets just something that is extremely rare for some reason? It looks like maybe the stock Sense 'Productivity' Lock Screen Theme sort of does this (from looking at it - but I've been using WidgetLock from the beginning). The problem with the HTC Sense is the configurability of the lockscreen isn't as flexible as I would like. I wish I could control which apps are in the dock on the lockscreen and how many there are (add app icons to lock screen) and how transparent the widget showing the info is. I hate the big clock too but want the productivity widget (the clock is always on the right in the notification bar - no need to waste space redisplaying it larger - my eyes are fine!)
Also, on Jelly Bean 4.2, I think I read you can add widgets to the lock screen. So does JB 4.2 essentially defeat the purpose of Widget Lock. I love that Widget Lock lets you go from a 4x4 grid to 5x6 (or whatever you want) so I can have 6 docked apps on the lockscreen and there isn't such big spaces between everything. I hope so as I can see the HTC Sense lockscreen sometimes come on for a moment before it gets replaced by Widget Lock. Makes me feel like I have a bit of a hokey setup to get what I want.
iOS had this same issue. But in 5 they greatly improved the lockscreen functionality. Then iOS finally introduced repeating notification settings. That's the next thing Android needs. But that's another subject.
