bern_viking
Hi
Following situation: running cm10 on a i9100.
I sync contacts with gmail, exchange and some other services (Whatsapp, skype, etc), I use the stock android app to manage them on my smartphone.
Is there a way to color-code the contacts so that I can see if they are from exchange (would be my work contacts) or from gmail (private/family), etc?
Ideally it should change the color of the names, as some of the contacts have pictures and changing the android robot color wouldnt help that much.
Thanks in advance.
Thanks in advance.
