A
Android Question
Guest
I just purchased a new phone (Inew V3) and I'm having some trouble with it.
Before putting my 2 sim cards in, I started installing some apps and everything was working perfectly.
When I was finished, I finally inserted my sim cards only to get the "Unfortunately, the process com.android.phone has stopped" error whenever I try to power it on. Initially, I thought it had something to do with the fact that I had been copying my old text messages from my old phone, and after rebooting it several times, I just gave up and decided to reset it.
That didn't work though, as I keep getting the same error, and am unable to use my phone with the sim cards on, since the error message keeps popping up.
Help? Thanks in advance.
