Help "com.android.phone has stopped"
  • Thread starter Thread starter Tablet Problem
  • Start date Start date
T
Tablet Problem
Guest
Alright, so after installing a new updates, I'm getting the "Unfortunately, the process com.android.phone has stopped." pop-up repeatedly. I have a tablet: ellipsis 7 from Verizon, but I guess it's powered by Android or something.
I've tried the Settings > Apps > All > Phone (mine says Dialar) > Clear data/cache
Didn't work. I tried similar things to this with different apps but that didn't work, nor disabling the Dial app.
How can I fix this? Should I just go ahead and do a factory reset, would that fix it? Is there another type of resent I can do (other than the one that shows up on the power off thing, already tried that.)
Hoping for a solution that doesn't require resetting, but I'm starting to give up.
Thanks for any help!
