command prompt
  • Start date Start date
A
Android Question
Guest
need command prompt to use ipcofig to get mac ip addreess for wifi mac filtering. not in directions; how do you get one?
I am assuming you want the command prompt on your phone. You will need to download a terminal app from the play store.
This should provide the command line you are looking for.
