rasta4rest
Member
Hi Folks , just to share for every user of C711 Commando Calculator.
Don't know if anyone just tried and having the same experience as i do, but apparently the "Hard Key Combos" to enter Recovery Mode is possible now for this lovely Calculator we have.
First thing you need to know , i still can't sure if this method can be applied to all of you guys , since i'm rooted my device from recovery instead of installing recovery from rooted device , so far the only cons for me is my C771 reset to its default number provided by fabricated Verizon Commando,since im not using Verizon as my provider , so i need to do some qpst to inject my provider number.
[Currently Live in Indonesia].
And i guess it's not a big deal for Verizon user,and since the phone functionality is the first priority , resetted radio configuration is not too much problem at all,except you flashed the radio.img that's the real problem.
For Those haven't know yet to do Hard Reset Combo here's the Guide :
Here's some image i got there :
After that just proceed by punching you Power Button , wait for moment , relax , then you enter the Custom Recovery Mode you've installed before [ GNM Recovery in my case]
That's it,No hidden trick nothing secret. :smokingsomb:
Do This from device state powered off:
"With the LED illuminated red, press and hold the Power button+Volume down key+Camera key simultaneuously then release.
The LED illuminates approximately 20-30 seconds after releasing the power button (step 2). The 3-key combination must be pressed within the 1-2 second timeframe that the LED is illuminated."
- Got this guide from Verizon official guide for detailed step by step.
