Wait, you're saying you've had more lag with your S3, than with the LTE?
Oh no, the SG3 is smooth, more lag with the evo 4g lte.
Since you've had both phones, I have to ask you which camera did you prefer? I have the GS3 but I think the camera on the LTEvo is better.
HTC really hosed the multitasking memory parameters, and then came out publicly and said that they meant to do it.
Evidently many don't use it in a way where the problem appears, I surely do. It's easily addressed with a root mod (night and day difference) so that's something for folks to consider - not everyone likes to root, while others wouldn't leave home without it.
Just repeating an earlier sentiment.
I am totally not against rooting if it fixes the issue. Can you explain to me what about rooting it fixes it (what rom, what do I need to do lol) I am a root rookie, but gotta start somewhere. i prefer my gs3 right now just due to the multitasking issue, but I want mt EVO back!
Depends which versions of the SIII are being considered, if it's the US versions I'd be more willing to consider competition as the hardware is just so similar.
But thankfully I'm not from the US so don't have to worry about such things, the international version with Exynos 4412 is the fastest currently available and I still very much favour Samsungs OLED displays.
Also I'm loving the battery life on my SIII, going 36 hours+ consistently is kinda nice.
I'll do my best.
As you may know, Android has all this fancy management going on to manage tasks and apps, shuffling them here and there in memory, putting them to sleep, caching them, and then killing them off when they're no longer essential at the moment.
All of those actions are controlled by a list of memory values - when there's this much left, do that, when only this much, kill that, now only this much, put that to sleep.
They're called the "minimum free" (minfree) and "out of memory adjustments" (OOM adj) and "virtual memory" (VM) values.
Adjusting them is like spinning the sides on a Rubic's cube - you have to be careful what you're up to.
Most all of the performance roms claiming better battery or faster speed tend to tweak those values.
HTC has made three apparent mistakes -
- The have set insanely high adjustment values. You can have lots of free ram while the system is busy lagging you and killing things off like crazy - including the launcher! lol
- They claim it's ok because Sense 4 is so much lighter. Ummm - have you seen the eye candy in that cool Recent Apps they have or in their new widget management system? Nice - but not light.
- The virtual memory values didn't change names but they did change in meaning for ICS. It's not clear to several of us that they got that right.
Good news - there is a generic rooting tool that will look at your system and auto-tune those values properly and it's sensitive to ICS.
http://androidforums.com/evo-4g-lte-all-things-root/561920-v6-supercharger-evo-lte.html
More good news - many of the custom LTEvo roms are using that tool as the basis for their adjustments, so you can pretty easily choose high performance roms with the solution baked in.
Even more good news - that tool doesn't care about brands or models, it's high-octane Android goodness, so anyone with any sorts of SGS3 performance problems and happy to root can check it out as well. It's pretty good stuff.
(I'm not knocking the SGS3, but I've seen the occasional lag or memory issue mentioned on the SGS3 forum, certainly not at the LTEvo level - but nothing is perfect, so I'm just saying - this is worth checking out.)
Thanks a lot. So after rooting, i should be able to multitask like I do on SG3??? I actually have no lag on the SG3 right now, but I did within a day of buying my evo 4g lte, my phone life womps lol
Fair's fair, not everyone complains about LTEvo multitasking, not everyone complains about SGS3 wifi performance. I think that much of that comes from both lines being new and the makers needing user feedback to improve the experiences.
Always a good idea to follow your gut on issues that matter to you though.
BTW, once you're on ICS, try Nova launcher. It's pretty good.
Thanks, EM. Between Nova Launcher and Apex Launcher, which one is better? Have you tried both? Only reason I'd stick with GLEx is because I have it completely backed up and it'd be an easy transition. And what nuances on Nova and/or Apex would be more ideal, since they're native ICS launchers?
GSIII Benchmarks...
Looks like EVO LTE wont have much to worry about in that regard. lol
Samsung Galaxy S III gets benchmarked, shows plenty of promise -- Engadget
I tried both Apex and Nova, and the first thing I experienced I can't articulate - Nova somehow felt better, more like an upgrade than a replacement. The rich feature set really locked me in (snaps on the LTEvo screen sharing thread, can't give a link just at the moment).
It's got a wide configuration range and you can save / restore setups.
Edit - this shows a tiny bit of it -
http://androidforums.com/htc-evo-4g-lte/555013-htc-evo-4g-lte-screen-scene-2.html#post4678099
The page transitions in the app drawer are very nice, smooth.
I really love the scrolling dock.
