Help Compatibility issues between GS3 and Parrot
calumski
Evening all, new here so apologies if this has been covered already...
I'm the proud owner of a GS3 that I've had for about a month now and I love it! Apart from a couple of niggles.
When I try and use the phone with my car kit (Parrot MKi9100) it doesn't get recognised as a USB device and I also can't get the track listings over bluetooth. When I had the iPhone 4 it worked fine when it was plugged in.
So... Does anyone know how I can either get the phone to mount the music folder as a USB drive when plugged into the car kit?
OR
Is there some way that I can get the track listings to be made accessible over bluetooth?
Thanks all, looking forward to becoming part of the club!
Cheers,
Calum
If you're running JB you probably have the same dock issue as I have with my Ibolt dock. They disabled the dock and aux features by mistake when they released 4.1 in the UK. Apparently a fix will come with 4.1.2 but god knows when ill get it with my carrier.
