jirka.h23
Member
If the phone does not have multi touch will the dpad not work?
if you upgrade to 2.2 froyo, then multi-touch should work
My 1st post on this site..
Also first time browsing this forum...
Im using HTC EVO w no 4g service.
3 days new to PSX4DROID and ROMBUDDYPSX purchased from market.
I cant get Final doom to work.. Is it possible?
FF7, Res Evil, Marvel vs capcom working...
Please help..
Thank you,
Greg
Having issues with ff8.
It has run acceptably well so far, I am at the beginning of disc 2. Currently at a part with an infamous glitch, the deck glitch. Right after an fmv plays, you are supposed to walk inside through a door. The glitch is that the door wont open, leaving you stuck. Various other emulators you simply have to mess around with the settings to get it to work, while mashing the open button. Not working at all with this emulator sadly.
The only thing I can think of doing is somehow using an emulator on my pc and making a new save, then transferring it over. I have no idea if there will be compatibility issues however. Could I please get some help here? I've put many hours into this game, really dont want to give up now.
I should note that I can get actual saves to work using epsxe, but theres a problem with this. My last real save is way back on disc 1. I've been using save states only for the entirety of disc 2. How would I go about getting these save states to work in epsxe as well, or another emulator?
.7z is a compressing method. You can just unzip the archive using 7Zip, then you can read the file right away.
Think of it as vowing clothes, then putting them in a tight box so it takes up less space in your car. Except after it, you have to open the box and get it out.
On a side note, you should get FPse as a PS1 emulator. It's MUCH faster then PSX4Droid, and way better supported.
Yeah I have done all of that abd on the Fspe the Iso didnt work at which is strange since its the firsy format they have on there. So I tried it with .bin and it worked until it loads the gaming part and wont get past that screeb. So I than tried putting that same file in the psx4droid and it actually worked problem is the choosing menu stays with a messed up discolored picture where you see what you are choosing whichs no sense its very frustrating.you have to unzip the .7zip file with 7zip or winzip etc.. first, then take the game file inside and see what format it is. If .bin you should be good to go and transfer to your phone and play. if you see .ecm in the file name then get a unecm converter. There are detailed instructions in the help section of PSX4droid for the unecm part
you can use IceTea to compress the iso or bin files to eboot files. i hear this also make some games work a little better. sometimes it will compress it down to half size
download it here
IceTea v1.3
If you are interested in following my compatiability list I will now be posting it on Zodttd's new developer site. The link to my list on his forums is below
Compatibility List by Trev 186
I will still monitor this forum but not as much. if you are interested in PSX4droid I recommend saving that site because Zodttd and Yongzh will be more active there.
could someone tell me if the incredible is good enough for play-station and 64 emulator's?
i plan on getting cricket with mine so i believe it limit's my options? is this the best to get ? this will be my first phone in 5 year's
theres to much to cover sorry i didnt search much.
