Compatible Accessories for AT&T S2?
bascotie
Hi guys,
I'm on eBay searching for a bunch of cheap accessories like a case and screen cover for the Galaxy S2. I noticed many models say "i1900" which is the (international?) model.
Does anyone know if the 'body' size of the Samsung S2's are the same, or are they carrier specific? If so, any recommendations on AT&T case covers and screen covers?
Thanks!
Hi guys,
Thanks!
The body size is the same, but cases and screen protectors won't interchange perfectly. The 9100 has a button on the face, the AT&T version doesn't, so the screen protectors are different
As for cases, the AT&T version has a noise cancelling mic in a different place than the 9100, so nearly every case out there right now will cover that little hole up. Not sure how much of an effect that will have, but I hate to disable something like that so I'm holding out a bit longer for a case made specifically for our phones.
