Compatible Charging Pads?
shadal
Are there any charging pads which are compatible with this phone? I found THIS LINK which shows the Powermat is compatible with the EVO 4G, I was wondering if that meant it would work with our phone as well.
Has anyone had experience with charging pads? Do they really work and are they worth the $70-$100?
They don't work with our phone. They work quite well with a compatible device, whether they are worth the money including at least 30% electrical losses as heat is up to the user. :rolleyes:
