Mirth
I posted this at another forum too, but I thought I'd share with you guys as well, since you're a great community too!
After doing some product dimension comparisons and research, I ordered a cradle that I thought might be compatible with our Optimus V phone, as a cheaper alternative to the LG Vortex cradle.
I present the Fosmon LG enV 2 (VX9100) Cradle
Buying/Info
Amazon Link: Amazon.com: LG enV 2 VX9100 USB Sync Charge Desktop Docking Cradle: Cell Phones & Accessories
Official Page: LG enV 2 VX9100 USB Sync Charge Desktop Docking Cradle
Includes:
• Cradle
• Micro USB
• A/C Charger
Pictures:
I took these using my Optimus V, with my sister's Optimus V in the picture.
And some stock photos from Amazon:
Notes:
• It MAY work with a case and WILL work without a case (works with my Body Glove Buttonless case, but have one report of it not working with the full Body Glove case).
• Hi-Speed USB 2.0 transfers. (I believe the LG Vortex cradle only does USB 1.0 transfer speeds)
• Has a charging LED to notify you that it's, *gasp*, charging.
• There is a Sync ---- Charger switch on the bottom so that if you want to use the USB just for charging, your computer/android won't pop-up with notifications about USB mode.
• The device stays in place just fine without the clear plastic holder that it comes with. The plastic piece prevents the phone from fitting, but it is meant to be removable so you can just pop it right off.
Buying/Info
Includes:
• Cradle
• Micro USB
• A/C Charger
Pictures:
Notes:
