Root Confused and in need of guidance
Hi the first thing is i want to say sorry.I know i am probably the 1000 newbie who comes here for help when there's hundreads of guides out there.
That's the problems i'm really confused by all the information out there.
I found a tutorial did as it said and got stuck. Can anyone tell me what seems to be the problem?
I'm running a 2.2.1 android version.I downloaded and installed drivers for HBOOT.
Then i launched unrevoked3 but it didn't work just said waiting for the device the same thing happens with revolutionary.But my ''boot screen'' says it's 1.01.001 so i don't see what's the problem?
And this is where everything stopped i don't know what to do.
Basically i'm in need of some guidance or a really dumbed down guide with correct steps to do with the state of software i am currently in.
My end goal was to install CM7.2
Update
After supposedly rooting my phone with superoneclick(couldn't install busybox) unrevoked3 finds my phone does everything correctly but at the end says ''failed to root is your firmware too new''
Does that mean i have to downgrade my hboot drivers or the android version itself(currently 2.2.1)
