Help Connect dead not sure why
xtenzzive
So phone ran battery all the way down to 0 the other night right as i turned screen on it said battery 0% and then went black. Since then it has not even hinted it would ever turn on again. 3 batteries, 3 chargers and a universal battery charger external from phone. Pulled sim and sd card in varying methods to try that out too cause it worked one day when it got hot. Also in the process of charging it in my truck it got a little hott...well really hott but i still had black screen prior.
Problem is i have rooted and installed black plague and with that i was suffering from a non sticking cpu profile which would occasionally max out at 1838mhz.....so yeah. Any hope you guys think?
I also hooked it up to my pc and it would make usb recognition noise from pc as i power cycled the buttons but pc would come up usb device has malfunctioned and no drivers found to install device. occassionally at random home keys would flash to but i couldnt narrow it down to a reason.
Put the battery in the charger. Plug the charger in. Check back tomorrow evening. By 24 hours, a "totally dead" battery should have enough charge to run the phone for a short time, at least.
If you actually ran the battery down to 0.01%, the internal safety disconnect popped, and an new battery would be cheaper than paying lab to open the battery and replace it. (Charging a totally dead Lithium Ion battery could be considered an act of terrorism - it'll make a pretty good, if small, bomb. So it internally disconnects before it's totally dead.)
Thanks for the reply! Charged 2 batteries over the last 48 hours straight one on an external from phone charger and one in the phone. They both got warm but still no sign of life from phone at all.
Just ordered the new BLU studio 5.5 s for 189.99 from amazon.
RIP connect...
