Just make sure to use the USB 3.0 port, because if you don't, it will be painfully slow...
Nothing is faster than the USB unless you have that hard drive connected to a Network Driver which can then transfer at LAN speeds.
WiFi is not a good choice usually, as it will just about cripple your local WiFi network when that big hard drive starts backing up.... Unless, you use a backup app that detects activity, and stops and waits until the system is quiet for 5+ minutes....
