Connect RAZR to computer
TXSooner
I had an Incredible that was rooted for most of its life so forgive me if this question's answer is "root".
Why when I plug my phone into my computer do I not get any prompts to use the phone as a disk drive? I wanted to transfer ringtones/wallpapers/mClock skins over. Instead I am having to use Dropbox.
When you plug it into the PC, is there a symbol in the notification area showing its connected?
Does the notification show up allowing you to choose to mount the drive? It should come into your notification area when you plug in. Then when you select mount your SD card and internal memory in the case of the RAZR will become available where your drives are found on your computer.
I noticed that when I hook the phone directly to the pc with the factory cable I get a usb storage notification but if I put the Mot external battery pack in line with the cable I don't get any notification. Same as my original droid.
Must be some different cable configuration.
You don't have to Mount the Razr like the OG Droid. Just plug it in using the charger cable that comes with it. Unplug the cable from the charger base and you have a USB connector.
