Connect to bt openzone
mcjeffreys
HI,
I'm on Vodafone and have now got bt openzone as part of my package. However I'm struggling to connect. Has anyone else managed to connect?
HI,
Hi mate, you were a little short in details, but ive found some info that might be usefull to you
How do I connect my iPhone to a Wi-Fi network when I'm out and about?
Monthly / Pay as you go
You can use Wi-Fi at any BT Openzone Premium hotspot while you're out and about. You'll find these hotspots in many public places like hotels, conference venues, airports, main rail stations, motorway service areas as well as in retail areas such as Starbucks.
To connect to Wi-Fi follow these simple steps:
1. First you'll need your vodafone.co.uk username and password. If you have not already registered or have forgotten your details go to Using WiFi with BT Openzone - Vodafone to register
2. Make sure you're in a BT Openzone Premium hotspot with Wi-Fi turned ON. The BT Openzone network name (SSID) will appear in your Wi-Fi networks list
3. Tap Settings > General > Network > Wi-Fi and then select the BT Openzone network by tapping it
4. You will be presented with the BT Openzone web page asking you to select your mobile provider. Tap the Vodafone logo
5. Next, you will be presented with the Vodafone login web page where you need to input your vodafone.co.uk username and password (go to Using WiFi with BT Openzone - Vodafone if you have not already registered or have forgotten your details). Your iPhone will store these details as one of your authorised access points and automatically connect to any BT Openzone Premium hotspot whenever it is in range.
Primary Navigation - links to other sections
My Account
* Using Wi-Fi with BT Openzone
Using Wi-Fi with BT Openzone on your iPhone
Related links
* Set-up Wi-fi on your iPhone
* Using Wi-Fi on your iPhone
* All iPhone FAQs
Here's what you need to do
If BT Openzone Wi-Fi is included in your price plan, you'll need to activate it by logging in to your Vodafone My account.
Not sure if Wi-Fi is included in your plan? Check by calling 191 from your Vodafone mobile (or 08700 700 191 from any other phone).
Vodafone Using Wi-Fi with BT Openzone on your phone
Hope that helps mate.
