Help Connect to PC Issue
Okay so I thought since I have so many mini usb cables laying around the house, I don't need to buy any extra micro usb cables, instead if I could just buy the mini-to-micro USB adapter, then I'd be good...
Well, not entirely... it works fine charging but when I connect it to the PC, my PC doesn't see it and the Phone wasn't mounting the SD card...
anyone got the same issue?
Thanks but I think it's not the driver issue since it recognizes my phone and mount the SD card if I use the cable that comes with the phone... it doesn't do anything only if I use the mini-micro usb adapter with a mini usb cable :)
Interesting... so I tried to install it again.. and voila it did cure the issue... I guess you were right, the driver did cure everything!!! lol
Thanks!!
