Hi , I own a huawei ideos X3, and am on tribe.
So, I wanted to connect the phone with usb. It is amazing, to find a path (within an day
. Not true, but by feeling.
First I did read here, drivers are needed and available. Until the startbuttom on the targetpage said "time over". Then I got a link to an support page from huawei. The file did not come ( 7 mb) until I used the right buttom , and got the download, with the name "downloadfile.htm". As I did know, that maid be wrong, I renamed it to "down.zip" and cold look what it is. It was the right package. So I anpacked all and got, "only for W7", for WXP use active sync. So I put my old active sync installation away and made a new one. And , to defend against all posible mistakes, I changed the micro USB cabel. I have one more tiny and one more thicker. ( For DOS veterans this is simple and normal)
That was the goal, not all copper thread where on both sides off my tiny cable.
Now as I connect the phone with the thick micro cable to the usb port, the pc found my phone and with explorer I wasted double and anused files on the phone and on the sd card. As I am happy I wish the same to all off you. Melobokus
