Help Connected to wireless, but no data transfers
Locane
Hi. I just got my Galaxy S Relay yesterday, and I'm already having an issue with it.
When connected to wifi, it will sometimes just stop transfering data between the internet and itself. The icons (up and down arrows) appear intermittently, but they do nothing.
This behavior manifests itself in the middle of data transfers and when idle. All internet connectivity ceases completely, even though I show a full connection to the wifi.
Sometimes, turning the wifi on and off again solves this issue, but sometimes not.
This issue has persisted across two separate wireless networks in very different locations; one with a D-link router and the other with an Apple Airport.
Has anyone else seen this or a similar issue?
Locane, you can try deleting the wifi connection on your Relay and re-entering it. Sometimes the files get corrupted. Also try unplugging the router for a minute before establishing the connection.
Normally, my Relay connects instantly to any of the networks I've registered it on. The wifi antenna is very good on this device.
