Apps Connecting Android to an offline SQL Database
lightmas
Hi all
I am very new to Android development, this is my first app :)
I am trying to connect my Android app (developing in Eclipse) to an SQL database which is placed on a local server (WAMP) but I am having a few problems (it will eventually nee to be on-line). I have followed a few tutorials online but kind of got stuck and am not sure whats going wrong.
I have the .php to the SQL working, its just the .php to the app :) The problem with this I am having is that when I run the project, all thats displayed is the URL of the php page and as I am so new to Android development its hard to know whats going on. Any advice would be appreciated. I have done plenty of Googleing!!
This is my Java code, if you need anything else just ask. I also have another version which just crashes onload.
package com.Conector;
import java.io.BufferedReader;
import java.io.InputStream;
import java.io.InputStreamReader;
import java.util.ArrayList;
import org.apache.http.HttpEntity;
import org.apache.http.HttpResponse;
import org.apache.http.NameValuePair;
import org.apache.http.client.HttpClient;
import org.apache.http.client.entity.UrlEncodedFormEntity;
import org.apache.http.client.methods.HttpPost;
import org.apache.http.impl.client.DefaultHttpClient;
import org.json.JSONArray;
import org.json.JSONException;
import org.json.JSONObject;
import android.app.ListActivity;
import android.net.ParseException;
import android.os.Bundle;
import android.util.Log;
import android.widget.Toast;
public class CityActivity extends ListActivity {
JSONArray jArray;
String result = null;
InputStream is = null;
StringBuilder sb=null;
@Override
public void onCreate(Bundle savedInstanceState) {
setContentView(R.layout.main);
ArrayList<NameValuePair> nameValuePairs = new ArrayList<NameValuePair>();
//http post
try{
HttpClient httpclient = new DefaultHttpClient();
HttpPost httppost = new HttpPost("Link");
httppost.setEntity(new UrlEncodedFormEntity(nameValuePairs));
HttpResponse response = httpclient.execute(httppost);
HttpEntity entity = response.getEntity();
is = entity.getContent();
}catch(Exception e){
Log.e("log_tag", "Error in http connection"+e.toString());
//convert response to string
try{
BufferedReader reader = new BufferedReader(new InputStreamReader(is,"iso-8859-1"),8);
sb = new StringBuilder();
sb.append(reader.readLine() + "\n");
String line="0";
while ((line = reader.readLine()) != null) {
sb.append(line + "\n");
is.close();
result=sb.toString();
Log.e("log_tag", "Error converting result "+e.toString());
//paring data
int ct_id;
String ct_name;
try{
jArray = new JSONArray(result);
JSONObject json_data=null;
for(int i=0;i<jArray.length();i++){
json_data = jArray.getJSONObject(i);
ct_id=json_data.getInt("CITY_ID");
ct_name=json_data.getString("CITY_NAME");
catch(JSONException e1){
Toast.makeText(getBaseContext(), "No City Found" ,Toast.LENGTH_LONG).show();
} catch (ParseException e1) {
e1.printStackTrace();
Thanks
lightmas
