Help connecting/disconnecting
MalikX
I have Lonovo A319 i want to flash it myself on pc but when i connect my phone with USB to my pc its keep connectimg & disconnecting i have dell window 10 any body tell me solution please
USB cables when they're new should be fine. However I know what usually comes with Lenovos and other budget Chinese devices, may not be the highest quality or reliable in the long term. Like they soon go loose, internal connections break, go intermittent, etc.
Is it disconnecting and reconnecting when you move or disturb the phone?
Another thing is, try another USB port, or even another computer. In case the PC's USB ports are flaky.
did your mobile is chargng well or airphone well connecting ? if yes you have no proplem with your port. you need to buy a better usb plug.
Hope that helps:)
