Help Connecting IP Cam to Sky Router> Through Android Hotspot
Jonny1717
Not sure if i should be posting this here or in a sky forum but hopefully someone can help me with connecting an IP cam.
Here is the setup
Sky Router > 50mtr Ethernet cable > Switch > Android Box (Wired) & PC Wired
As the sky router is way out of range i have a hotspot setup on the android box which i use for internet, everything from laptops to phones connect and run fine. My problem is im trying to connect a wirelss IP motorola Pet hubble cam.
In the setup sequence (Through the hubble app) it finds the wirless hotspot connection then when i try to connect to it it periodically connects then drops, it says error 3 (Which means cannot connect to the internet)
Any suggestions or can i even connect to it through a hotspot ? ITs for a borading kennels, there is no way of moving any equipment about so it has to be through the hotspot.
Any help appreciated
