Rarewolf
Android Expert
Been wanting to play games with an existing controller i have
(an XBox1 Controller)
i ended up buying this USB female to USB C male
with a Male Micro USB to Male USB with USB 3.0 to USB C
connect it but it keeps saying
"On the old Device, Make sure the USB connection is set to File Transfer Or Media Device (MTP)
Drag down the status bar for the notification panel and change the USB connection if needed"
change it to charge device and also tried MTP device and Charging but nothing happens, looking through apps to see if anything is gonna get it to run.
