Root Connecting to Wifi causes CM7 to freeze / hang
Sveden
I have a Nook Color with CM7.2 installed.
I seem to have bonked the wifi drivers in some fashion. When I try and connect to a hotspot the wifi connection Icon will appear, say it is connecting and then my entire Nook OS freezes. I notice the status bar drop and disappear as the system becomes unresponsive.
Is there a way to re-install/overwrite just the wifi drivers in CM7?
This happened once before and I think it might have something to do with me being impatient and sleeping the system while it was connecting/disconnecting.
You could reflash your rom. If it's the same rom, same version or close to the same version, all you need to do is clear cache and Dalvik cache.
