Help Connecting zenithink Z130 to WIFI
i recently bought Zenithink Z130 but am unable to connect to WIFI.
I try to connect to my virgin media account which shows up in the settings of my tablet, but when i connect it says first remembered and then disabled, but am unable to connect. ( altought the signal strength is excellent )
Also it scans the WIFI but nothing happens. I thought it would be easy to connect but i may do something wrong. Any advice?
have you done the WIFI tx fix? how far are you from the router, the antenna in these units suck and the range is really lousy.
Hi, What is the WIFI tx ?
When i turn on my tablett i click on 'turn on wifi' then is starts to scan.
It says then 'connecting' to my internet network which is usually use at home.
But then it shows as 'diconnected' again.
I am about 1 meter of the router.
Hope anyone can help me
