Here's the series of events:
Thanks!
- Unlocked Nexus 5 on AT&T prepaid plan started randomly disconnecting from cellular data, saying "No SIM card - Emergency calls only". A reboot would fix temporarily.
- Fixed some settings at the AT&T store and tried a brand new SIM card - didn't fix the issue. AT&T said they've done all they can do and that it must be a device issue.
- Google sent me a replacement N5
- Replacement N5 now suffers from a similar, yet different issue. Instead of getting the No SIM card error, I am getting cell service but no data. I see the typical signal icon in the upper right of my screen, but it has an exclamation point next to it. Happens as soon as I get off of Wifi. Reboot fixes it temporarily.
Thanks!
