I am having issues with the contacts/addressbook on my Alacatel 918D and was wondering if someone can recommend a fix. On my N+kia, I used to move old contacts from the phone to the sim card, but configure the phone to show contacts from the phone only. That way, the dead weight would be out of the way, but for incoming calls the phone would still recognize them.
With my android phone...
- ...it isn't even possible to copy single contacts from phone to sim - all I can do is import or export the entire set.
- ...when I send a text message, my phone shows me ALL contacts (phone and sims) even though the phone is configured to show the phone contacts only. According to Alcatel, this is Android behavior and the way it should be.
Can anyone recommend a solution for these issues? Maybe there's a "better contact app" or something that will kill both birds with a stone, but of course I'm also open for separated alternatives.
Many thanks in advance!
