A Android Question Guest Aug 30, 2015 #1 my max started loosing my contacts they disappeared how can I fix this
Lana30 Android Enthusiast Aug 30, 2015 #2 Hope this helps, http://www.androidphonesoft.com/resources/recover-lost-contacts-from-android-phone.html
El Presidente Beware The Milky Pirate! VIP Member Aug 30, 2015 #3 ^Those recovery solutions rarely (if ever) work unfortunately. OP, if they're synced to Google, head here: https://contacts.google.com/u/0/preview/all Then using the menu on the left hand side of the page select more, then restore contacts.
F Fliohyer Lurker Apr 15, 2016 #4 How to sync the contatcs with gmail: to sync go to settings-->Google-->[your account]-->menu-->Sync If you need to consider some app to solve the problem.Downloading the trial version.
