Contacts Map to GPS
Hi
Im new to android so forgive if I do not explain well.
I am looking for a app that when i open a contcat in my contacts lists will give option to direct me to them via gps.
Hope my request makes sence as this would be very handy for me.
Thanks
My contact address information is stored in Outlook. After syncing my device, the address info is also on my phone.
Home > People > [contact name] > Navigation button next to the address
A prompt will popup asking which navigation app to use with the option to set one as the default.
You can do this with the stock Google Maps or Navigation. As long as you have the address in the contact, just start typing their name inthe the Search box or the Get Directions box, and it will take you there.
