Help Contacts not saving.
rwh1218
I have a rooted Prevail with CWM and Honeybread5 installed. When i try to save contacts it tells me saved but they are not showing up in the contact list. What needs to be done to make them show up?
Unfortunately I can not tell you how to solve this as I have been having the same problem, but until it gets fixed you can go to txt msg or where ever and start typing out the name and it will show up even though it is not in your contacts list. Weird shit, I know.
open up your contact list and tap your menu button and tap display options and see if anything in there is set wrong. if its something else just try reflashing your rom and if that don't work start from scratch with odin :P
Remember to do what wetbiker said. Boot into cwm and do a factory reset, wipe cache, wipe dalvik cache then start from scratch :)
Start from scratch and redo your phone. Make sure that you do a factory reset, wipe cache, and then wipe the Dalvik cache. That should do it.
Do what wetbiker said. But don't install a theme. I've had this issue before, completely reinstalled the ROM and everything and it solved it's issue, then instead of installing the pink me theme, installed the red and blue theme and it started doing it all over again. Something to do with the themes...
