contacts storage
  • Start date Start date
A
Android Question
Guest
some of my contacts have a g next to them.
i have found them in my gmail account
but how to do i get the other contacts onto my gmail?
Edit the contact (one at a time). You can change it there.
Or you could export all your contacts, change them in the exported file, delete all your contacts and import the file. (If you don't delete the existing ones you'll get duplicates - importing adds, it doesn't replace.)
