Control G2 from PC. Is it possible?
Can I mirror G2 screen to my PC and control G2 from my PC? Is there an app for it?
Thank you.
Yes you can with OSP:
Direct Download Link: http://tool.xcdn.gdms.lge.com/dn/downloader.dev?fileKey=OW00220111201
OSP(On-Screen Phone)
LG On-Screen Phone is the service that allows you to view and manipulate your phone remotely via a PC, with the keyboard/mouse input from
the PC. You can also easily exchange data between the PC and your phone
FEATURES
1. You can write, send and receive messages(SMS or other messengers) via PC.
2. You can transfer file contents in Gallery, Music, Video Player, Office Viewer in your phone to the PC by drag & drop.
3. You can easily transfer files from the PC to your phone by dragging & dropping.
4. You can get real-time event notification from the phone.
5. You can see the whole pages of Home Screens in Panorama View. (Only with LG Home)
6. Multi-touch input using keyboard/mouse.
RECOMMENDED SYSTEMS
Windows XP (SP3) 32bit /64bit, Windows Vista 32bit/64bit, Windows 7 32bit/64bit.
Warning : On Windows 2000 (sp4), you can run the program but some of the drivers may not work properly
CAUTIONS
1. You can use LG On-Screen Phone Service only with the supported phones. [supported phone list]
2. To use LG On-Screen Phone Service, you should connect your phone to PC via USB, Bluetooth
Super. Will this OSP allow me to use any app on my phone via PC? Can I maximize it to the full PC screen instead of the "virtual" phone view?
I will try it with the USB cable. However from the look of it it should be what I need to.
