piludo36
Member
https://play.google.com/store/apps/details?id=com.yirgalab.dzzz
It's a VPN that prevents apps from connecting and using data, until you activate it. Most will shut themselves down. These are apps that non-rooters couldn't stop before. Also you can choose what apps you want to function "normally".
It's free, add free and isn't intrusive.
With know this phone loves to munch on the battery, even all bloat disabled.
Greenify is a great idea but it caused my phone to malfunction and I had to do a factory re-set.
For Commando, Doze is the one.
You can also Green Power Battery saver. Only if to enable sync schedule. I'd probably dump it if gmail had more options, than just "push"
