Cool features
Hi,
Does anyone have any cool features that they just discovered by accident (or research). It would be good to share this with others!
if you're using a AT&T branded HOX and you install a launcher through the play store, you can get easy access (through the apps list) to some of the apps that AT&T for some reason had HTC keep out of the sense launcher apps list. (i use voice recorder all the time, for example)
