Hi and welcome to these forums - hopefully we can help you here.
Normally to copy to the clip board you long press the text field (URL) and an option to copy all, clear & paste etc. appears and you select what you want. It should be the same when using a stylus. If you are in the middle of a text document (SMS etc) long press and 2 cursors should appear which you can drag to select a portion of text. Ther should be copy/paste buttons showing at the top.
