Hi folks,
is it possible to copy all data from a htc desire to samsung galaxy s?
i could probably sync contacts from outlook to galaxy but would really like to copy texts and audio files.
thanks in advance
). I previously had a rooted HTC hero with an 8GB SD card, can I just switch this across into the new phone? Ideally I'd like to clean out any junk I don't use any more from the card, so is formatting it the best way and the S2 will just refill it wit the folders it needs?
Hi All,
Rather than start a new topic I tought I'd tag on here!
I should be getting my Galxy S2 tomorrow (missed the delivery today). I previously had a rooted HTC hero with an 8GB SD card, can I just switch this across into the new phone? Ideally I'd like to clean out any junk I don't use any more from the card, so is formatting it the best way and the S2 will just refill it wit the folders it needs?
I don't really have any apps added onto the SD card, but am I right in thinking these will download fully from the market when I switch phones as these are linked to my Google account?
Thank you for any replies!![]()
When I use Google to sync my contacts, do they take the use as their right to siphon off and use all the email address and names in my contact list for their own use?
Why not backup your messages with some tool like MyBackUp Pro on your SD card, and then install same tool on new phone insert SD card in it and restore messages, calendar, bookmarks...
