waldopepper
Not sure if this is something to do with what apps etc I have installed but I can no longer use the copy/paste function on my Galaxy S3!
It's running 4.0.4 on Three network (UK) and I don't think this was caused by any recent operating system updates. I use Swiftkey as input but the same problem happens with the stock keyboard.
In some apps I can cut text, but pasting doesn't do anything.
Long pressing on one character space no longer brings up the copy/paste menu, I have to highlight a word then this menu is visible, but paste doesn't work.
Also when using Chrome, when I try to copy or past a URL it stops Chrome working completely after freezing for a few seconds.
Has anyone had any similar issues?
Is there a way of restoring features like this to their default settings or is it just a part of the operating system?
