Help Couldn't install on USB storage or sd card with XXLPB
Shocky
Android Expert
Just installed the latest beta and getting this error when trying to install apps from the market, it will only give this error when the external sd card is installed, it's fine if I unmount the card.
Is anybody else getting this?
Also I realize it's its a beta so no stupid comments please.
I tried it yesterday and found it unstable, it would not let me restore via CWM so i had to falsh back to LA2 via odin and then i could restore with CWM.
I've had no problems with crashes, it's very stable so far and the performance is fine.
Just the sd card issue that's the problem, I can work around it though.
i've been reading the XDA forum. someone said if you unmount the SD card, you can install the app. Then just re-mount the SD card after installation. I haven't tried it as i reflashed the rom without root as i was having the same problem. let me know if it works.
