Couple simple questions
rgonz29
How do you forward a txt message to multiple people in your phonebook?
and is there anyway to customize the blank screen when texting or emailing?.... love the phone just takes a bit getting used to the tips and tricks.
oh how do you delete a downloaded ringtone?
Thanks
When you add the first person, touch just to the right of the number to place the cursor there. Just start typing and it will pull up your contacts in the same way as it did for the first contact....add as many as you need.
