What is the best program for showing how much CPU time a app has used,
and for how much battery percentage a app has used?
Why do you think whether it interests you is relevant? This isn't your thread.No idea. Doesn't really interest me, TBH.
For troubleshooting. Same sort of reason you'd look at what applications and processes are tying up the CPU on your PC.But maybe I'm wrong. Why do you want to see how much CPU time an app has used?
If that's the case you have a bad app (or apps) you need to deal with. Task killers aren't best practice for dealing with battery issues. They can and do adversely affect battery life as well. However, if you can't give up the problem app(s) then the task killer is probably your only recourse.I also use 'Advanced Task Killer' two or three times a day to kill all the apps dead. Yes, I know they come back up after a couple minutes, but nevertheless my battery life has improved enormously since I do that.
Why do you think whether it interests you is relevant? This isn't your thread.![]()
