Hey tamir297, welcome to our AndroidForums!
At the risk of posting before those that know math much better than I do
p), I'll just chime-in with my brief thoughts:
Quick answer: I believe it would be 0.5 seconds (i.e., your app kept the CPU busy for half of the one second interval).
Whenever I've typically cited CPU usage, it's usually in terms of the percent of utilization over a given time period.
In your example, I would say that your CPU was 50% busy over that one second. If you knew the max. CPU speed (1 MHz in this case), you'd be able to figure-out that you you averaged 0.5 MHz over that one second of time.
Your app didn't (and probably couldn't) use all 100% of the CPU's capacity (1 MHz) because it was probably in a sleep state or waiting for an I/O operation to complete, etc.
Hope that helps!
edit: Oh, I forgot to mention that I still have a Z80A chip that ran at 4 MHz that I was going to use to "upgrade" the original Z80 chip (2.5 MHz) in my Kaypro II from back in the early 1980s. I never installed it, though
