Help Crackberry had it right when it came to contacs....
anyways, to make things short
my curve 8320 had an option to set ringtones to contact groups. I have already figured that out but a few things..
I have setup contact groups via gmail and synced them than used Group Ring to setup custom ringtones for each group.
Now here's what I need.
Is there a way to ONLY make the groups ring and ALL other calls silent? If i put the phone on silent nothing will come thru so how do I make it so only calls on the contact list ring?
not here. I honestly did not know you can group your contacts with a special ring unless doing it one by one.
What about youmail? I know you can group several people into a special voicemail. Select the ones you want to hear and the rest straight to voicemail.
if you export all your contacts to gmail, put them into groups, than sync your gmail with your phone you have contact groups. than just use Group Ring which is free and your done.
