Help Cracked Screen; No help from Google or Samsung
ni3po42
I had my Nexus 10 for 3 weeks when it slipped off my counter face down and cracked the glass on the screen. I've contacted Google for service; They direct me to Samsung; Which Samsung would direct me to Google. The table still works fine (as long as your are OK with cutting your finger on the screen). Am I out of luck or is there anything else I can do?
you might try a screen protector to "cover" the crack and prevent cuts... other than that, it's time to start looking for a Samsung authorized repair shop or perhaps a laptop repair shop (hopefully they can order & replace your screen). Good luck.
