Help Cracked screen
jhnelo
I have just looked at my beloved x10 and noticed I have somehow cracked the bottom right of the screen. An it has spread across the whole front. I am absolutely gutted! Just want to cry. Is it easy to refit myself of just take it some. I am with three UK. Can they do anythink? Thank you
Here are replacement screens:
Sony Ericsson XPERIA X10 LCD Display Screen Tools_Cell Phone Parts & Repair_Cell Phone_Eketshop Wholesale Electronics, Consumer Electronics, Cheap Discount Electronics Supplier
New Original LCD Screen for Sony Ericsson Xperia X10
Or check ebay
And here is how to completely disassemble the x10:
Xperia X10 Disassembly Guide | Xperia X10 Blog
That, or find a cell phone repair store. I assume your phone is no longer any sort of warranty?
Anyone else have any other suggestions?
Or check ebay
I haven't check out the links you've supplied yet but will do when I'm home as of the warranty I haven't had the phone longer than 12 months so I should have it bit how do I go about it? Just phone up my provider? Thanks
I chipped the corner of my x10 and it annoyed me everytime i looked at it. i went on ebay got new housing, its your probably your cheapest option but the product wasnt genuine although i have no problems with it so far
Doing it yourself was easy since the package came with tools and instructions so as long as you have those you should be fine, dont forget to check the feedback on prooduct just incase
Could you give me the sellers name over PM please? Thankyou
