I've found that this phone's ability to transfer from 3G to 4G data is absurdly slow, if not completely useless. It also seems that it will never switch if there is data transfer in progress. The only reliable way to make it work is to airplane for about 10 seconds, then turn it back on. If there is 4G coverage, it will come back on immediately into 4G.
Example of a common daily routine... When I leave work and walk outside, there is full strength 4G. But the phone will be sitting on 3G from when I was inside. It will not switch to 4G unless I airplane it first to cut it off and back on. The 3G data here is literally like a dialup 14.4 modem. So it will just sit there trying to sync or do whatever its doing until the cows come home. It will never change to the readily available 15mbs 4G data.
It is so bad, I had to make a tasker function to airplane, wait 12 seconds, and turn it back on. I made it a widget called "Reset 3G/4G".
Any way to fix this crap?
